synch with lose it duplicating food logs
 I noticed recently that the synch that’s always worked well from the lose it app over to Fitbit, from my inspire 3, has all kinds of extra food logs being created. all is correct within the lose it app. It is the Fitbit app that is the problem.. I have tried all sorts of things and am at a loss for how to fix this. It seems like there might be a bug in the Fitbit application that was perhaps introduced recently. Would very much appreciate some help on figuring this out. It’s causing major frustration. Thank you so much
2 REPLIES 2
I’m having the same problem, everything was fine and then noticed the app was duplicating the exact same meals 5 or more times for the day. It’s aggravating. 😕 not sure what changed.
Same issue here just recently.  I disconnect from both cowboy and lose it and reinstalled but continues to happen
