04-23-2018 08:59
04-23-2018 08:59
can the myfitnesspal app not sync with the versa? i can't even find the app on my list
04-23-2018 09:12
04-23-2018 09:12
MFP will sync with fitbit, regardless of the device. I used it no problem with my blaze and am using it now with my versa.
04-23-2018 09:32
04-23-2018 09:32
MFP does not have an app on the unit. It is a third party program that links and syncs with your Fitbit database. What you need to do is go to the MFP website (assuming you have an account, if not you can create one free of charge) and then go to the apps and find Fitbit then give it your Fitbit login information. It will then link up with your Fitbit account.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
04-23-2018 10:27
04-23-2018 10:27
it JUST started working..thanks guys
08-30-2018 22:07
08-30-2018 22:07
Did you get it to work where it’s on the actual Versa screen?
11-18-2018 15:16
11-18-2018 15:16
How did you get the app to add to your versa screen?
