weight loss not syncing with myfitnesspal
hello!  I started using MFP before I got my Fitbit.  everything else syncs just fine but my weight loss progress on the Fitbit app only counts what I've lost since I started using the Fitbit.  is there a way to correct this?  I've tried manually entering my weight from the original start date but it doesn't seem to recognize it.  I've also done the uninstall/reinstall, disconnect/reconnect dance.  nothing seems to work.
thanks!
1 REPLY 1
Hello @TinaKills, welcome aboard to the Fitbit Community. Note that this is the way it works this integration. Your weight will be transfer to MFP only if you have on your Fitbit account an Aria Scale. Manually log weight wont be recognized and can only be recorded on your Fitbit account.
To learn more about what information syncs your Fitbit account with MFP, please take a look at this chart:
Fitbit > Steps > MFP
Fitbit > Calories > MFP
Fitbit > Aria measurements > MFP
MFP > Logged food > Fitbit
MFP > Activities > Fitbit
Hope this helps. Keep me posted if you have more questions.
Roberto | Community Moderator
