10-08-2020
23:53
20:52
10-08-2020
23:53
20:52
can i make a phone call from my watch or do i need a special app
can i ring a abulance from my phone
10-09-2020 07:02 - edited 10-09-2020 07:04
Hi there @goosse, welcome to the Community Forums. I'll be glad to answer your inquiry about making calls on Versa 3.
Please note you cannot make calls directly from your watch, however, if paired to an iPhone or Android (8.0+) phone, Versa 3 lets you accept or reject incoming phone calls. If your phone is running an older version of the Android OS, you can reject, but not accept, calls on your watch.
To accept a call, tap the green phone icon on your watch's screen. Note that you can't speak into the watch—accepting a phone call answers the call on your nearby phone. To reject a call, tap the red phone icon to send the caller to voicemail.
The caller's name appears if that person is in your contacts list; otherwise you see a phone number. For more information, see: How do I get notifications from my phone on my Fitbit device?
Note you will be able to take calls soon in a future update. Please keep an eye out for it.
Let me know if there's anything else I may help you with.
10-10-2020 08:52
10-10-2020 08:52
So you can confirm there will definitely be an update for the versa 3 in which you can answer the call and use the built in speaker and microphone to talk? I was hoping so, as the hardware is obviously there.
I have just brought a versa 3 and I’m so disappointed and feel a little mislead in terms of advertising as I can’t actually speak through the watch currently when conducting a call 😔
10-11-2020 00:20
10-11-2020 00:20
Yes, specs all said built loudspeaker but can't take calls on versa 3.
Even my Huawei honour magic does this well. Disappointed in Fitbit. I sure hope there is new software otherwise I will have to send it back. Not equal to advertising.
Must say I love the rest of watch. Really very slick.
10-11-2020 01:53
10-11-2020 01:53
Taking calls on the fitbit is definitely coming. The press release says:
"Stay connected with a range of smart features for added convenience, including a built-in speaker and microphone to take calls and reply to texts with voice commands"
However, there's a footnote to that comment in the press release that says:
"Available when phone is nearby. Bluetooth calling and volume control coming soon"
I've not seen anything that's more explicit than "soon" so we need to just wait a while.
10-24-2020 13:03
10-24-2020 13:03
Fitbit says on the verse 3 you can make and receive phone calls, but is this a feature becoming available with Google only Assistant? As it does have the built-in microphone and speaker, and everything that I read said Alexa may be compatible but that it was going to be released when the Google Assistant was released... So does this mean that you have to use the Google Assistant in order to make a receipt phone calls or will it just be released at the same time so that way I can still use the Alexa assistant?
10-24-2020 22:24
10-24-2020 22:24
Does the answering feature will come soon? Otherwise I can change the phone.why I have to pay more?
11-11-2020 13:28
11-11-2020 13:28
Will this be available for the iPhone?
12-07-2020 15:23
12-07-2020 15:23
I feel mislead on the music and phone aspect of the versa 3. But my ionic refused to run again after the Dec. 4th update. So had to get another and read the apps incorrectly apparently.
12-08-2020 08:54
12-08-2020 08:54
My husband and I bought two versa 3 last week. His phone will receive calls and he can talk over it. Mine won't, it just accepts the call on my phone. !!???
12-08-2020 09:57
12-08-2020 09:57
Thank you. Glad to know it's not just me.
12-29-2020 07:10
12-29-2020 07:10
You have to go into settings, best thing is to google, I have had mine almost a week and still setting it up now, have you got your microphone turned on in your settings on your Fitbit?
01-28-2021 11:49
01-28-2021 11:49
Hi,
I just bought a Sense.
Why you can only receive a call but cannot make one using Alexa or Google?
Is this feature coming?
It’s being quite a disappointing customer experience so far.
01-28-2021 12:39
01-28-2021 12:39
I have the Versa 3 and wanted to do the same thing that’s why I bought it as previously had the blaze and wanted newer model so chose this over Apple Watch (got a good deal on Versa 3 basically new) however the google assistant does say it’s a feature coming soon so they need to pull their finger out before I go apple instead
04-20-2021 18:04
04-20-2021 18:04
Has this been updated yet? Can you actually have a phone conversation via the versa yet?
06-01-2021 21:04
06-01-2021 21:04
I just got the versa 3 recently and now (6months after this post) it does seem that this feature has been activated to answer calls directly on the watch, is there a way to make calls on it that I can't figure out or is that part still on the way?
06-01-2021
22:20
12:30
EdsonFitbit
06-01-2021
22:20
12:30
EdsonFitbit
I get a notification of a call coming in and can accept or delete, but can’t actually take the call on it,have to pick up the phone. Haven’t done any more research on that, wish it would work.
05-27-2022 15:14
05-27-2022 15:14
I have the versa 3 and you CAN answer a call and talk through the watch as well as quick replies for text messages. That's the reason I purchased the watch to answer calls from it. Works with no problems as long as your phone is nearby
05-27-2022 15:15
05-27-2022 15:15
I know this reply is late but you can answer calls and talk through the watch on the versa 3.
05-27-2022 15:18
05-27-2022 15:18
The versa 3 you can answer and talk through the watch
