01-31-2023
21:26
11:02
01-31-2023
21:26
11:02
I understand that you guys don't have any plans to add third party apps or enable the Wi-Fi
At least add basic features like
1) Music playback control
2) Ability to change installed watch faces without having to use the app every time
3) Being able to adjust the brightness of always on display (even if it affects battery life)
4) A calculator (if possible)
5) google Calendar or just a local calendar app
And I see you guys added unoptimized watch faces directly from previous versions of Fitbit watches, some of them won't even function properly, I see a disconnect between you and the developers. This is what they had to say.
" Fitbit wrongly assumed all Versa 3 apps should or would work on Versa 4 and is making my clockface available for Versa 4 owners."
01-31-2023 23:46
01-31-2023 23:46
Hi @MehulGera - Fitbit ported older clock faces to the Versa 4/Sense 2 platform without informing the developers but as the architecture is different some may not work.
As the developers don't have access Fitbit added "not optimized" for the non Fitbit clock faces.
As regards the missing features these are unlikely to appear, certainly music won't as it is largely being phased out by Fitbit across even existing models.
Why so many features were removed on this model is a mystery.
You can always add or vote in the feature suggestions forum as this forum is primarily for user sharing. Though once a feature was already deemed not necessary it isn't likely to get added.
02-01-2023 08:18
02-01-2023 08:18
Sorry, @MehulGera the "you guys" that you are addressing are the fitbit users in this community for fitbit owners.
We, and the Mods, really have no insight on why, or who made these decisions.
Our guess will be as good as your guess.
