10-08-2023
09:00
04:06
10-08-2023
09:00
04:06
After updated fitbit app, versa 4 can't connect Alexa. What's going on?
I can't find any buttons for voice assistance or Alexa setup.
Please fix this problem ASAP.
It looks worse than before update.
Best Answer10-09-2023 02:55
10-09-2023 02:55
Welcome to the Fitbit community, @Ksang1965!
Sad to hear that you have an issue with Alexa on your Versa 4. As I'm having absolutely no problems using Alexa while running the new Fitbit app, I'd conclude that this is not a general issue issue. So please have a closer look at 'What should I do if my voice assistant doesn’t work on my Fitbit smartwatch?' following the link below as a first approach to hopefully get things fixed for you:
How do I use a voice assistant on my Fitbit smartwatch?
I'll keep my fingers crossed.
