09-02-2025 05:22
09-02-2025 05:22
Is there a way of having the heart rate displayed always when exercising, currently I have to keep on waking it up.
Best Answer09-02-2025 06:21 - edited 09-02-2025 06:21
@funkytwig Go to the settings for that shortcut -- swipe up on the tiny "^" at the bottom of the screen. There is an Always-on display option at he bottom of the screen.
Laurie | Maryland
Best Answer09-02-2025 07:57 - edited 09-02-2025 08:14
Thanks, kind of got to screen swiping up from ^ but times out and starts exercise in a few seconds, not enough time to do anything.
Best Answer09-02-2025 08:41 - edited 09-02-2025 08:43
@funkytwig It sounds like you are selecting one of the three icons from this screen.
Those are Quick Start shortcuts of the last three shortcuts you used or the ones loaded by default. You can't change settings from there. Tap on All, then select the shortcut you want from the list. Now you can change the settings.
Laurie | Maryland
