10-04-2022
05:58
19:02
EstuardoFitbit
10-04-2022
05:58
19:02
EstuardoFitbit
Battery life was at about 7+ days expected, until it reached 12%, after 6 days, then it went to 0% in 2 hours.
This reduced the full battery from 100%-0% of over 7 days to under 6 days.
Hence perhaps the 35% low battery warning - the last 10% can't safely be used.
Even in the app it says not 10% if it is under 10% - very odd battery behaviour.
Charging it, it needs only 130 ma, instead of 300ma for a Sense, which implies the battery of about 162 mah might be confirmed, against 266mah for a Sense / Versa 3.
See Sense 2 / Versa 4 battery issues
10-04-2022 06:48
10-04-2022 06:48
You may be onto something. I also noticed on Sense 2 that the last 99% to 100% charges a lot longer and it looks like GPS drains more power than on Sense (I believe it's the same GPS hardware but as you said, battery capacity is just lower).
10-04-2022
09:32
10:57
10-04-2022
09:32
10:57
