07-17-2023 17:20
07-17-2023 17:20
I just received a Versa 4 and was hoping that I could use the C25K program (or a similar running coach) on it. I found the C25K app for Fitbit, but it says that it is not compatible with my device.
Is there another app or function that supports a similar coaching program?
Thanks!
Best Answer07-17-2023 23:42
07-17-2023 23:42
@Crowned1 there are no thirdparty apps for Versa 4. If you are looking for an in-warch training guidance you won't find it.
