04-12-2023
05:58
08:48
04-12-2023
05:58
08:48
I can use my fitbit versa 4 to receive voice calls but is it possible to initiate voice calls from versa 4 ?
04-12-2023 06:24
04-12-2023 06:24
Hi @mahmoud.atiya81 - the Versa 4 does not support call initiation directly but if you have Alexa you may be able to do it that way. Basically the watch is merely used as a microphone to Alexa. You may not be able to talk over the watch though, just try it. There is no Google Assistant alternative.
04-12-2023 06:24
04-12-2023 06:24
