06-01-2025
18:09
06:13
06-01-2025
18:09
06:13
I would like the battery status - percentage of battery life - to display on the main screen of my Versa 4. Is this possible? If so, how do I add that? Thanks.
06-02-2025 05:20
06-02-2025 05:20
Hello @Jbemi and welcome to the Community. Try searching the Gallery for a clock face that includes battery percentage.
Laurie | Maryland
06-02-2025 06:30
06-02-2025 06:30
Hi there, @Jbemi. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post, we're here to help you!
As @LZeeW has suggested, try searching for a clock face that includes the battery percentage on the main screen by following the steps shared with you.
On the other hand, keep in mind that you can also check the battery level on your Versa 4 by swiping down. The current level appears at the bottom of the screen. Also, you can view your device's battery level from the Fitbit app by tapping the Today tab > devices icon. The battery level appears to the right of your device.
