Can I swim with my versa 4?
Can I swim with my versa 4? I'm worried the water will damage it
2 REPLIES 2
@Jodie88 Welcome to the Fitbit Community.
Thanks for being a part of the community and sharing your questions with us.
Please note that most Fitbit devices are water-resistant to 50 meters. They're designed to be swimproof and stand up to even the sweatiest of workouts. I do recommend taking a look at this article "Can I swim or shower with my Fitbit device?" so you can learn all about your Versa 4 resistance.
Hi @Jodie88 - note the bit about seals deteriorating over time - for that you should be able to swim happily while the watch is under warranty because if it fails it can be replaced - while it might continue to be fine err on the side of caution thereafter in case you are unlucky and moisture gets in.
It may take weeks if there is a leak before damage is done, so it may not be prudent to use up till the last minute of the warranty
