12-02-2022
20:39
06:27
12-02-2022
20:39
06:27
Hi is there any way to or a chance to have the fiton app on fitbit versa 4? I see it is not compatible. It worked great with versa 3 and now I am surprised it is not supported in the newer one
Best AnswerNo, and apparently neither that app nor any other from 3rd parties will be available ever. That means you'll be restricted to use the basic preinstalled apps from Fitbit and that's all, in case you were wondering.
Best AnswerWell, okay, so apps or other stuff that was available for Versa 3 are now not available for Versa 4. Too bad! Thanks for your reply
Best AnswerWhat a disappointment that it is no longer available as an upgraded product 😞
Regretting buying another fitbit, should've bought a Garmin after the skin sensor isn't working and now its incompatible with my apps.
