11-26-2022
20:42
06:45
11-26-2022
20:42
06:45
My Versa 4 alerts when I get a message from Snapchat but it doesn't allow me to read the message on my watch.
11-26-2022 23:10 - edited 11-26-2022 23:12
Open Settings → Bluetooth. Tap on the (i) next to your Fitbit Sense device.
Enable the toggle for Share system notifications.
If the steps above do not help,try these additional steps:
Turn off all notifications on Sense:
The last I can think of is reset your phones settings.to default values:
11-27-2022
12:45
06:44
11-27-2022
12:45
06:44
None of that helped. I still receive a Snapchat notification on my Versa 4 and when I tap to open it says “open link” with what looks like a paper airplane. I’m beyond frustrated. My Charge 4 used to all me to read Snapchat messages, now I upgrade to the Versa 4 and unable to.
Update: Correction….it says “link sent” when I try to open Snapchat message on Versa 4.
11-28-2022 06:44 - edited 11-28-2022 06:46
Hi there, @MichelleA1971. Thanks for stopping by in the Community Forums and troubleshooting the issue with your Versa 4 before reaching out. I understand how you must be feeling. @LokeAa Thank you so much for your help!
In addition to the steps you've done so far, please try the following:
Also, please check if "Preview new messages". To do so, open the Message+ app, then go to "Settings", then "Notifications", then "In-app notification settings", then enable "Preview new messages".
If the above wasn't enable, try enabling it and then test your notifications to see if they can be open the way it's expected.
I've moved your post to the Versa 4 board for organization purposes.
Hope that helps.
11-28-2022 11:29
11-28-2022 11:29
Im not having a problem with text messages. I’m have a problem with messages from Snapchat app. I receive the notification on my Versa4 but for Snapchat but when I tap open, it says “link sent” on my Fitbit device. I’ve done all the troubleshooting suggested. I have Snapchat notifications turned on in Fitbit app as well which is why I’m getting the notifications. I just can’t read what the notification is from Snapchat specifically.
11-29-2022 17:16
11-29-2022 17:16
I think I misunderstood you, so had to test myself. I also get "link sent". When I tap "Open" the snapchat image appears on the phone. The watch cannot display the snap directly on the device.
11-29-2022 21:42
11-29-2022 21:42
I was able to read Snapchat messages on my Charge 4, obviously not pictures or video but Snapchat texts.
