09-14-2024
13:20
08:50
09-14-2024
13:20
08:50
in training modes that involve the use of positioning, such as running or cycling, it is not possible to enable GPS in the settings
Best Answer09-16-2024 09:59
09-16-2024 09:59
Hi there, @vGrigoriy. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 4 and for the image attach. I will do my best to help you with this!
Please keep in mind that only activities where you cover physical distance outdoors, like a run, walk, hike, or bike ride, offer GPS tracking.
If you haven't done so yet, I'd recommend restarting your Versa 4 by following these steps. Then, to turn on GPS for an exercise on your Versa 4, please do the following:
To start an exercise with GPS on your device, please go outside, then open the Exercise app on your device and tap an exercise. Only activities where you cover physical distance offer GPS tracking. Wait a few moments for GPS to connect.
Tap the play icon to start the exercise. If the GPS signal disconnects, your phone or Fitbit device continues to search for a signal. Note: If you previously turned off GPS for an exercise, turn it back on before you start the activity.
Best Answer09-18-2024 06:26
09-18-2024 06:26
I have restarted the device, and selected workouts such as biking or walking, but the GPS enable is not active, impossible to enable.
