05-06-2024 18:15
05-06-2024 18:15
Time for a new exercise tracker. I have two apps on my current Versa (original) that I have found extremely useful. 'Agenda' which gets it's data directly from Google Calendar. The other app is 'To-do' where you can enter and update a to-do list from my phone, and can check off items directly on my Versa (original).
I understand for the Versa 4, third party apps are not available.
Thank you.
05-06-2024 20:26
05-06-2024 20:26
Hi @Jim5211 - you are correct, neither the Sense 2 or Versa 4 have those apps, or any extra apps. They are missing other features found on prior models too.
If you need those features a Versa 3 or Sense original or Versa 2 should have them.
If you use other apps or clock faces a Versa 2 will probably support them, but check if they are available on the other two because they have a different geometry and not all are converted for them.
