01-20-2024 12:48
01-20-2024 12:48
Hi there!
So when I select run on my versa 4, it maps my run route as well as all other stats. However now when I walk it only gives me stats and no map.
Ive tried to search help etc but cant find anything relevant. When it’s on auto it says gps won’t be switched on but I’ve no way of changing that. And this happens even when it’s not auto recognising the walk but I’m actually selecting it.
Also my location services are set to always on.
Any ideas please?
Best Answer01-20-2024 22:56
01-20-2024 22:56
On Sense 2 GPS was disables for Walk so I believe it is on Versa 4. Go to Exercise tile (not exercise shortcuts tile) and select Walk, swipe up for Walk settings, turn GPS on. Should help.
Best Answer01-21-2024 01:36
01-21-2024 01:36
Thanks for replying but I dont have that option. When I go to exercise tile and swipe I just go to the bottom of my list of exercise done. Unless I’m in the wrong place but can’t see anything else obvious.
Best Answer01-21-2024 01:45
01-21-2024 01:45
Sorry, worked out now you mean on the versa 🤦🏼:female_sign:! Not used to having so much functionality on the actual watch. Sorted now. Thank you.
