How can I see the battery level in my Versa 4?
Is there an area on the watch that shows the battery level?  I have a new phone but it isn't reflecting the battery charge accurately.  Thanks!
2 REPLIES 2
Hey there @Tricia65, nice to see new faces around!
Thanks a lot for taking a step forward and getting in touch with us through the community. Let me help you out!
Here is an easy picture that shows some basic movements and shortcuts you can use with your Fitbit Versa 4:
As you can see, you can swipe down to access Quick Settings. Down on the screen, you will see the battery percentage. By the way, you can also go ahead and check the information here.
HI @Tricia65 - just pull down on the watch face to get to Quick Settings and you can the battery level there. You may find many good clock faces in the gallery.fitbit,com that even show it directly on the watch, some with warnings when it gets low. I use SimpleClockPro.
Changing phone can be an issue to get it syncing again, make sure the old phone is switched off and if necessary set it up again using the Fitbit App on the new phone so that a new Bluetooth connection is made for it [add new device and then replace].
