04-11-2024
10:10
07:24
04-11-2024
10:10
07:24
My Versa 4 screen has changed in the last couple days. I have it set up to read the time all the time. Normally after a few seconds the main screen goes away and I only see the time. Now all I get is the main screen with the seconds readout not changing. The screen is bright for a few seconds and then it dims, at the point that it would change to the time only. I hope this is clear.
Best Answer04-12-2024 05:16
04-12-2024 05:16
04-11-2024 10:27
04-11-2024 10:27
Hello @gkgeiger and welcome to the Community. It sounds like your always on display got turned on. Swipe down on the screen to go to your Quick Settings. I bet the bottom left icon (looks like an analog clock) is on. Tap it to turn it off. The touch screen is very sensitive. Inadvertent swipes and loose sleeves can easily make changes.
Laurie | Maryland
Best Answer04-11-2024 10:45
04-11-2024 10:45
Best Answer04-12-2024 04:58
04-12-2024 04:58
@gkgeiger I'm sorry that I misread what you wrote. What clock face are you using? Can you post a picture that shows the problem?
Laurie | Maryland
Best Answer04-12-2024 05:08
04-12-2024 05:08
04-12-2024 05:30
04-12-2024 05:30
04-12-2024 07:28
04-12-2024 07:28
Hi there, @gkgeiger. Welcome to the Fitbit Community Forums. I'm glad to hear that the steps recommended by @Guy_ did the trick. 😊 @LZeeW Thanks for trying to help!
For more information about this feature, please see How do I see the time on my Fitbit device?
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
