01-06-2024
04:21
04:16
01-06-2024
04:21
04:16
Is there a way to set alarms so they automatically repeat the next day. I have to reset them every day. On my Versa 2 they reset automatically.
Best Answer01-07-2024 04:21
01-07-2024 04:21
Hi there, @Misty223. Thanks for stopping by in the Fitbit Community Forums and the details provided in your post about the alarms not repeating daily as they were on your Versa 2. I will be glad to help you!
As a first approach, please note that alarms you set in the Alarms app onn Fitbit Sense, Fitbit Sense 2, Fitbit Versa 2, Fitbit Versa 3, and Fitbit Versa 4 are separate from alarms you set with your voice assistant. For more information on using your voice assistant to set alarms, see How do I use a voice assistant on my Fitbit smartwatch?
Please confirm that you've set up your alarms correctly by following the steps below:
Note that on Sense, Versa, Versa Lite Edition, Versa 2, and Versa 3, alarms won't go off if your device has less than 8% battery.
Best Answer01-08-2024 07:19
01-08-2024 07:19
