09-09-2023
12:03
07:46
09-09-2023
12:03
07:46
I how do stop getting the reminders to move?
Best Answer09-09-2023 13:05
09-09-2023 13:05
Hi, @Pvoorheis , you need to turn this off in your app. From the, opening, Today screen click on the icon top left. On the next screen click on the picture of your Fitbit (Versa 4) . You will see that Reminders to Move is turned on. Click on that tile and toggle RTM to off.
If you don’t want them all day every day you will also see the option to change the hours in which you get them, and even the days (for example if you want weekends off, etc)
Whenever you make and changes in the app be sure to sync your Fitbit.
09-09-2023 13:05
09-09-2023 13:05
09-10-2023 09:17
09-10-2023 09:17
09-15-2023 13:53
09-15-2023 13:53
Hi, @Pvoorheis , I am glad you were able to solve your issue by following my instructions. I would be grateful if you could make my post as the “best answer” as that might help other people searching a solution for the same problem.
