01-11-2023
13:59
07:27
01-11-2023
13:59
07:27
Is there a way of stopping the buttons from vibrating. I hate the vibration!!
01-12-2023 09:26 - edited 04-27-2023 20:37
Hi @Justyna180622 - the only option is to set vibration to weak in the watch Settings. If you are getting vibrations because of touching the button you can't stop that. If you are getting them from receiving notifications the only thing to do is stop receiving them, by using do not disturb.
04-27-2023 20:24
04-27-2023 20:24
That isn’t working either, running on do not disturb, turned off all notifications except email low battery and still it vibrates like crazy about stuff I don’t want to be disturbed. I’m taking it off and throwing it it won’t stop!!!! It’s of no value if it’s that’s bothersome! There has to be a way to stop it!
04-27-2023
20:42
16:35
04-27-2023
20:42
16:35
Hi @SunsetRunner - in the Fitbit App tiles there are things like reminders to move which can be turned off, along with auto recognition of automatic exercise detection, which can be annoying.
Even within exercises there are Settings, so if it signals events while exercising turn the options off.
