03-28-2024 07:32
03-28-2024 07:32
I have just upgraded from Versa to Versa 4. I set up the new device and it seemed to connect fine after the software update which it did first. My problem is that the Active Zone Minutes (AZM) weekly goal is set to 1 minute, so every minute while I am walking I get a lot of buzzing on my wrist to tell me I have achieved 234x my weekly goal, then 235x, and so on... Basically whenever I look at my wrist, I only ever see the AMZ weekly goal achievement. I was able to set the AMZ daily goal on the fitbit app on my phone (I set it to 2500 to avoid it ever being reached), but for the life of me, I can't find where to increase the weekly AMZ goal from 1 minute. After reading various other threads I have done all the things that I thought might help, like turning off AMZ goal reminders on the watch, turning off notifications on the app, putting the watch into do not disturb mode, resetting the watch, doing a factory reset. But all to no avail, it still buzzes every minute while I am walking. Any help much appreciated.
Best Answer03-28-2024 08:53 - edited 03-28-2024 08:54
Hello @wooden_tree and welcome to the Community. How very odd. I hope I can help. This is the path on the iOS app version. Tap on your profile picture/gear icon in the upper right > Activity & Wellness > Daily Activity. The Active Zone Minute weekly activity goal is there. It looks like you need a very large number.
There seems to be a bug in the Versa 4/Sense 2 settings. My Goal Reminders are toggled off on my Sense 2 Settings. I still get that weekly goal celebration from time to time. I just keep raising that number.
I thought the default was 150 minutes. How annoying.
Laurie | Maryland
Laurie | Maryland
Best Answer03-28-2024 11:55
03-28-2024 11:55
Thanks LZeeW,
That has worked! I had assumed the Daily Activity thing was for Daily Activity, but indeed that's where the weekly goal was lurking. I have increased it to 3000 and now I can walk without my wrist buzzing the whole time. The default seems to be 1 minute weekly goal, or at least it was for me when I started.
Problem solved - hopefully others will benefit too.
04-04-2024 14:19
04-04-2024 14:19
I see this and I’ll do the same. However Fitbit should be set up so you can track whatever activity and not be required to have a goal. Sometimes you just want to know what’s going on without needed a reward.
