Hey there @Hartgh! It's nice to see you around.
Thanks for sharing your questions about using the Versa 4. Let me explain:
First, you'll need to open Settings on your device and select Shortcuts. From there, you can choose the specific feature you would like to open with that shortcut.
You can also visit this help site for more information and tips!
@Hartgh I apologize if I misread your post, but I interpreted it different from @EstuardoFitbit. I looked at your profile and can see that you used a Fitbit for several years. The Versa 4 has over 40 shortcuts and they are all on the device. You don't control the exercise shortcut list from the app, like on older models. The shortcut list will separate into your recently used and all the rest as you use the Exercise app. The recent section holds you last five shortcuts.
Many, many users (like me) would like to remove shortcuts we will never use. Unfortunately, we can't edit the list.
If this doesn't answer your question, can you ask it a different way?
Laurie | Maryland
