How to stop watch constantly restarting when changing clock face
In the Fitbit App 3.73 there may be a problem with changing clock faces on a Versa 4 or Sense 2, causing the watch to constantly restart.
The constant restarting can block any new clock face from loading, even with a 60 seconds display timeout.
To stop the constant restarting process, logout of the Fitbit App and swipe it off, clear the cache and force stop it. This will allow to the watch to finish starting with the last active clock face.
While you are not logged in the watch should work normally again.
Next time you login to the Fitbit App immediately go to the Gallery tile, it will ask "later or continue", choose later, but it continues anyway [a long standing issue never resolved], select another existing clock face.
Repeat the whole process and this time choose later and when you click the clock face that won't load, you will be able to click Cancel.
The problem may occur when loading just some clock faces. Fitbit Layers seems to be one of them.
0 REPLIES 0
