Hi everyone,
I have a fitbit Versa 4 and a Google Pixel Watch 2 and I would like to use both in different way: for example, during the day i would like to use the Pixel Watch and while i sleep or when i go to swim i would like to use the Versa 4. If i understand well, is impossible to sync both device simultaneously in fitbit, but i have trouble also tryng to switch from one device to the other.
Yesterday, when i tried, i wasn't able to reconnect with the versa 4, also after a reset of the versa 4. How can i do?
What is the best way for use in the way i described? Thanks to all!
Best AnswerHi, @IlPedro88! Unfortunately, you're correct, this is the only way to use two devices at the "same" time.
MakMak | Community Council
