02-13-2023
08:13
10:45
02-13-2023
08:13
10:45
Is my versa4 waterproof?
Best Answer02-13-2023 08:22
02-13-2023 08:22
Hi @Oakmont see Page 67 of the user manual
02-13-2023 10:07
02-13-2023 10:07
Hi @Oakmont - the specs say
"Water Resistant
Water resistant to 50m. After getting the band wet, we recommend drying the band because, as with any wearable device, it's best for your skin if the band is clean and dry. Learn more."
The Pixel is more precise
"Water Resistance
Water resistant to 50m (5ATM).
Google Pixel Watch is designed to comply with water protection ratings of 5 ATM under ISO standard 22810:2010 when manufactured, but it is not waterproof. Water resistance is not a permanent condition and decreases or is lost over time due to normal wear and tear, repair, disassembly or damage. Dropping your Google Pixel Watch may result in loss of water resistance. Google Pixel Watch is designed to be used in shallow water and should not be used for activities involving high-velocity or high-temperature water. Some accessory bands are not water-resistant. See here for details."
So while it's under warranty it can always be replaced but after that it is at your risk. Though avoid heat and showers/baths/saunas and detergents.
