10-02-2024 13:22
10-02-2024 13:22
I have a Versa 4. When I am walking, I want to see my heart rate. Is there a way to change the data that is displayed?
And if you tell me to go to the "Fitbit App", where do I find that - online, on the watch? I need step-by-step instructions. I've read several comments and I'm confused.
Thanks.
Best Answer10-02-2024 14:46
10-02-2024 14:46
Hi @marstar the actual Fitbit app is what is on your phone. You should be logged into your account and open the app to see your dashboard. That dashboard has the different stats on the one screen, Your heart rate is below the steps. If you want to see the heart rate on the Versa 4 while walking, you'd need to select the watch face that does that. You can change the face on the app by going to your dashboard, tapping on the device upper left which takes you to another screen where you select "Gallery" and then "Clocks" to find a new watch face that might display the heart rate the way you'd like. I have the Inspire 3, so our faces would be different.
10-03-2024 13:22
10-03-2024 13:22
@Odyssey13 Thank you for sharing the info .
@marstar , A warm welcome to the Community! Thank you for your message and Information.
Just jumped in, to add to Odyssey13's info. If you want to see the heart rate during the activity, tap on the screen of your Versa 4. You can change the stat shown on the Versa 4's display while you are recording your activity!
10-03-2024 15:42
10-03-2024 15:42
I also would like to show my heart rate while exercising. Not in tiny numbers where I need to stop and put on reading glasses.
Your instructions are not clear. My dashboard on my phone show # of steps. There is no upper left option that goes to gallery, rather it goes to connect another device, then to update tracker software and option stuff to purchase.
Best Answer10-03-2024 15:51
10-03-2024 15:51
Never mind, found it.
Best Answer10-04-2024 12:53
10-04-2024 12:53
10-04-2024 15:31
10-04-2024 15:31
Vera 4 has funny quirk. Exercise mode appears to shut off if I stop for 20min. When hiking, exercise mode works up to lunch. I don't realize it shut off until mid-afternoon. Not Useful.
