11-21-2022
11:24
08:35
11-21-2022
11:24
08:35
Is there a way to save a timer? I often use a 3 minute timer. And I have to recreate it each time which is a pain.
Best Answer11-22-2022 04:59 - edited 11-22-2022 05:57
The Versa 4 can have up to 3 saved timers. It also remembers the last used timer without explicitly saving it, so if you always use a 3 minute timer, it should show up below the default 5 minute and 10 minute timers anyway. To create a timer, when you are on the Timer screen on your Versa 4 you should see the ellipsis (3 dots) button - click on it, click on "Add timer", set the duration of your timer, click on it to start it and then press the pause button immediately, when the timer is paused scroll down and click on the "+" button. Your timer should be added to the list of timers. Also, see How do I set a timer or use the stopwatch on my Fitbit device?
11-24-2022 21:29
