11-14-2023
09:03
04:05
11-14-2023
09:03
04:05
Is there a way to disable the always-on display on my watch when I’m not wearing it? I only wear the watch occasionally, and I’ve noticed that the battery lasts much longer when the display is off. I often forget to turn off the always-on display manually.
Best Answer11-15-2023 03:26
11-15-2023 03:26
Hi there, @eddie778. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post, we'll be glad to assist you with the inquiry!
If you're looking to turn off Always On display, please follow @Talahthas' directions. More information can be found here.
On the other hand, if you want to turn off your Versa 4 completely to preserve battery life when the Fitbit device is not in use, you can turn it off by following the steps below:
Hope that helps!
Best Answer11-15-2023 02:53
11-15-2023 02:53
Welcome to the Fitbit community, @eddie778!
You can easily toggle the AOD on and off by swiping down from the clock face to access Quick Settings and tapping the icon to the left in the bottom row.
11-15-2023 03:26
11-15-2023 03:26
Hope that helps!
