10-05-2025 10:38
10-05-2025 10:38
None of the answers in the forums have worked, the watch only responds when I have it on the charger, take it off and reattach, the logo flashes followed by the red X. The only page it goes to is language followed by the help page about the app, but when I go to the app in the phone it will not sync. Did the phone turn off and on, remove and re-add the app, turn Bluetooth off and on, but can’t find the device. In the Fitbit app, Says connected to Fitbit, shows the Versa 4, hit sync your device and even though it says connected, the last sync was at 5 am yesterday. Now, after several minutes it says not connected and starts looking, finds it and reconnects but not syncing. And, in the Bluetooth app it says connected to Versa 4. I have an IPhone SE and have had the watch and same phone since 2023.
10-05-2025 18:19
10-05-2025 18:19
I have had the same problem all day today!! So frustrating. I thought possibly there was a software update, bc Everytime there is, I have a problem with it synching!! Grrrr!!
10-06-2025 02:49
10-06-2025 02:49
I've been having this same problem too!
10-06-2025 16:14
10-06-2025 16:14
Having the same issues since yesterday big red x and constant restarting
10-06-2025 21:02
10-06-2025 21:02
Best Answer10-09-2025 04:16
10-09-2025 04:16
I just got my watch 2 days ago and it was working great and after the update its not working and I get a red X when I try to restart.. Very
Best Answer10-30-2025 09:25
10-30-2025 09:25
I was looking for answer because I faced the same thing for my versa 4 - flashing screens and red cross. I found the solution and back here to help. Apparently, I learnt that this is a factory reset mode and I followed this YouTube video step by step and I managed to go back to normal : Get out of Factory Reset mode
Best Answer10-30-2025 09:26
10-30-2025 09:26
try my solution above
Best Answer10-30-2025 09:27
10-30-2025 09:27
Try my solution. I posted above.
Best Answer10-30-2025 09:30
10-30-2025 09:30
May not be a battery issue, it’s software. I was stuck after factory reset but the YouTube video helped me. Posted above.
Best Answer10-30-2025 09:31
10-30-2025 09:31
It’s a factory reset mode. I found a way to solve this red cross. Watched the YouTube video link posted above.
Best Answer10-30-2025 09:33
10-30-2025 09:33
I solved my red cross. Posted solution above. Try. Worked for my versa 4. I hated the software update. Factory reset and found myself with flashing screens and red cross and the YouTube video was helpful. I followed step and step and got back my normal screen.
