03-28-2025
15:25
05:44
03-28-2025
15:25
05:44
New to Fitbit and I can’t figure out how to get my messenger notifications to show on my Fitbit. I have tried going into my Fitbit settings but there is no place with apps to select.
Best Answer03-28-2025 22:23
03-28-2025 22:23
HI @ElizabethSwierk - you will find for your device, Notifications where the main options are selected and also App notifications, while this shows all apps on Android it is a bit special for iPhone. See
How do I get notifications from my phone on my Fitbit device?
03-29-2025 05:49
03-29-2025 05:49
Hi there, @ElizabethSwierk. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the steps you've tried so far. I'm sorry to hear that you are still having difficulties to enable your notifications. We're here to help you!
Have you tried what @Guy_ shared with you? Please note that since you're setting up your notifications, you'll need to receive a message from the app desired in order for your app to show it as an option in your Fitbit notification section. For example, tell someone to send you a WhatsApp/Messenger, then check your Fitbit app and you'll see that WhatsApp/Messanger is already an option to be selected.
Best Answer03-29-2025 06:19
03-29-2025 06:19
Thanks I did get it figured out. I had to click on the battery percentage which I had no clue was also a drop down menu. Everything I was seeing was telling me to click on the picture in the corner, which did take me to Fitbit settings but it was not the actual Versa settings.
03-29-2025 08:24
03-29-2025 08:24
@ElizabethSwierk- yes this is very confusing for users.
Google changed the layout for some unknown reason rendering all previous instructions and examples incorrect which leads to unnecessary confusion and is not nearly as logical as the Fitbit way was.
Well done for finally getting it working.
As you see, the forum can be a good place to get answers, if you have more questions.
