My Fitbit keeps sliding off the charger and doesn’t sit central and doesn’t charge ?
2 REPLIES 2
Hi @Oli8764 - try rotating the watch through 180 degrees [top at the bottom] before attaching the charge cable.
Hi @Oli8764 and warm welcome to the forums.
I appreciate your message, and I'm sorry to hear that your Fitbit keeps sliding off the charger and doesn’t sit central and doesn’t charge.
I understand your feelings about this situation, and I'll be more than glad to suggest you some tips.
Make sure you use the charging cable that came with your device, as most cables aren't compatible with other devices.
Check the alignment and try reconnecting your device to the charging cable.
The steps for charging your device are listed in the following help article : How do I charge my Fitbit device?
@Guy_ Thank you for the support always given, I appreciate it.
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
