12-26-2024
07:45
07:59
MarioSFitbit
12-26-2024
07:45
07:59
MarioSFitbit
Brand new Versa 4. When trying to sync it was frozen on a screen that said connected. It did connect to my phone briefly but now my phone can not locate it. It seemed to happen when I attempted to update the versa. I attempted to restart by holding the button for 10 seconds. The versa buzzes and the screen is black. I have done the reset a few times now and the only response is the quick buzz.
Best Answer12-26-2024 14:21
12-26-2024 14:21
Hi @Humbugice. Welcome to the community forums.
Thank you for providing the information regarding this difficulty with your Versa 4 and for trying to fix it on your own.
I'd suggest you try the following in the order listed:
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer12-26-2024 15:15
12-26-2024 15:15
I tried this suggestion and it still says that the Versa is not found. Should there be green lights on the back because mine does not have that
