05-28-2024
09:32
10:06
05-28-2024
09:32
10:06
Just bought a Versa 4 and it started the setup process, and now it won't swtich on or charge.
05-28-2024 10:14
05-28-2024 10:14
Hi there, @MysteryAngel. Thanks for stopping by in the Fitbit Community Forums. I'm sorry to hear that your Versa 4 is not turning on nor charging. I will do my best to help you!
If you haven't done so yet, please restart your Fitbit device as suggested here How do I restart my Fitbit device?
If the restart doesn't work, may I know if your Versa 4 vibrated during the process? Does your Versa 4 display the Fitbit logo by any chance?
05-28-2024 11:32 - edited 05-28-2024 11:32
Thanks for your reply.
I have tried to restart doing all the suggested as above and still nothing. I don't remember it vibrating, and the screen is blank no logo.
05-28-2024 11:36 - edited 05-28-2024 11:51
@MysteryAngel Thanks for getting back and the details provided.
It sounds like your Versa 4 may have run out of battery during the set up process as the firmware update also requires your device to be fully charged. Nevertheless, please try putting your Versa 4 on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
When it has had two hours, try restarting your Versa 4. I would recommend trying this maybe twice in a row if a first try doesn’t work.
05-28-2024 11:40
05-28-2024 11:40
Ok i will try that and see if anything happens. It did say it was at 80% charge when it was updating the software.
05-29-2024 09:30
05-29-2024 09:30
Thankyou so much for your help. Left it on charge over night and now it's working.🙂
05-29-2024 09:40
05-29-2024 09:40
@MysteryAngel You're welcome! I'm glad to hear that the steps provided did work for you!
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
