11-10-2024
03:38
06:14
FatimaFitbit
11-10-2024
03:38
06:14
FatimaFitbit
I had a Versa3...worked well for under 2 years then suddenly wouldn't sync. Spent hours trying to resolve problem but nothing. Decided it was kaput so just bought a Versa4. Same problem. I now have 2 unusable Fitbits 😡. I have looked at everything on line but unable to find a contact (:-(
Best Answer11-10-2024 20:44
11-10-2024 20:44
Same here but with an Ace 2 and Ace 3. Neither the old or brand new product will sync. Hopeless app. I raised a ticket with support two weeks ago and no progress has been made.
Best Answer11-11-2024 00:31
11-11-2024 00:31
Best Answer11-12-2024 02:24
11-12-2024 02:24
The latest update came out today and it fixed syncing on both my devices! Version 4.29 on Android 14.
11-13-2024 00:06
11-13-2024 00:06
Best Answer11-13-2024 06:11
11-13-2024 06:11
Hi there @Sophrentie and @Jimmyroz! A warm welcome to the Fitbit Community!
Thank you for reporting this situation and for all your efforts!
@Jimmyroz Thanks for the update. I'm glad to know that your devices are syncing normally again!
@Sophrentie Please try to do the following:
Best Answer11-13-2024 07:55
11-13-2024 07:55
11-13-2024 08:07
11-13-2024 08:07
Hi @Sophrentie! Thank you so much for your answer and for all your efforts.
Could you please check in the Play Store if you can update the Fitbit app?
Best Answer11-13-2024 11:14
11-13-2024 11:14
11-16-2024 06:11
11-16-2024 06:11
Hi there @Sophrentie! Thanks for your answer and for your efforts.
Can you share with us If it worked?
Thank you in advance for keeping us updated.
Best Answer11-16-2024 13:06
11-16-2024 13:06
