01-04-2023
08:56
06:26
01-04-2023
08:56
06:26
Twice I’ve reset my versa to enable me to receive calls and notifications and it’s stopped working again. Every time I reset I do not get updates on other features due to having to wear my device for so many days. How can I sort this out? I’ve tried other troubleshooting like turning the “share system’s notifications” on and off. I’ve had it working twice so why does it just stop?! '
09:35
10:27
01-04-2023
09:35
10:27
Hi @Bexgsi - the most common causes for it stopping working are, the watch face was pulled down and Sleep or Do not disturb was enabled or the battery saving settings on the phone is shutting down the Fitbit App, Bluetooth or location.
See Why won't my Fitbit device sync? for more tips.
Best Answer01-04-2023 23:08
01-04-2023 23:08
Hi
the do not disturb wasn’t enabled and I am connected to Bluetooth. I can’t get it working and looks like I will have to remove device to set up again. Never had this issue with my versa 2.
23:19
10:27
01-04-2023
23:19
10:27
@Bexgsi - if Sleep is not enabled, first try logout of the Fitbit App and restart both phone and watch. And try again.
Presumably by reset you mean restart but if you mean factory reset, then remove the Bluetooth entry from the phone and do " Set up a Device" again and replace.
Best Answer01-05-2023 00:07
01-05-2023 00:07
That hasn’t worked. Yeah I did the full reset twice to get it working and then it just stops working. I don’t want to keep going that as I won’t get updates on the tiles that require to wear your watch for 3 nights etc
00:13
10:27
01-05-2023
00:13
10:27
