On-wrist calls aren't working on my Versa 4
I am not able to answer calls or get calls on my versa 4. It has paired with my android phone but when I go to Bluetooth to connect it, I get the message app needed to use this device.
The sleep data sync to phone but the Bluetooth isn't letting me  connect the versa 4
1 REPLY 1
Hi there, @Bonitabs. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with the on-wrist calls on your Versa 4. I will do my best to help you with this!
As a first approach, please note that the Versa 4 Controls might be listed as “Not Connected” in the list of Bluetooth devices on your phone. When you receive a phone call, the controls automatically reconnect.
Nevertheless, I'd recommend verifying the following:
If you continue having issues, try the following troubleshooting steps:
  1. On the phone, turn Bluetooth off and back on.
  2. Restart the Fitbit device once gain. For instructions, see How do I restart my Fitbit device?
  3. Remove Versa 4 Controls from the list of Bluetooth devices on your phone.
  4. Set up on-wrist calls again. For instructions, see How do I set up on-wrist calls on my Fitbit device?
