02-10-2023
04:05
04:46
02-10-2023
04:05
04:46
I'm not getting wrist notifications for my phone calls on my Versa 4.
02-10-2023 04:47 - edited 06-12-2023 10:39
Hi there, @Estabrookn. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 4.
If you can’t answer on-wrist calls, check the following requirements:
If you continue to have issues, try the following troubleshooting steps:
Note that your Fitbit device's controls or calls might be listed as “Not Connected” in the list of Bluetooth devices on your phone. When you receive a phone call, the controls automatically reconnect. This feature requires more frequent charging.
Best Answer02-10-2023 04:47 - edited 06-12-2023 10:39
Best Answer02-22-2023 09:45
02-22-2023 09:45
And if all of these troubleshooting steps still do not work? I have even called in and had them walk me through everything and it still does not pair to on-wrist calls.
02-22-2023 15:35
02-22-2023 15:35
Same here if I knew I would have these issues I would have went with one that didn't offer on wrist calls but that's the main reason I went with it. I've called and stayed on phone for 30 mins still no help says connection error every time I try to answer it
02-26-2023 10:57
02-26-2023 10:57
So after you do all of that 10x's. plus factory reset 2x's, and uninstall app4 x's. and still no on wrist calls? Fitbit will show i am getting a call, then when I accept it, it times out and then an error message. All notifications come through. Wallet does not work, Weather app sporadically works. Alexa works great. I understand you are having a problem with wallet but the on wrist calls was why the watch was given to me as a gift. It worked well for a month then no more. If you look up my history you will see. You really need to replace this with something that works. Thank you for your time.
PS I am not troubleshooting any more on this.
Best Answer07-13-2023 09:01
07-13-2023 09:01
It's July 2023, I just got my versa 4 and I see from the dates of this thread that the issue still hasn't been corrected....
