04-26-2023 14:34
04-26-2023 14:34
Since the thread started in 2017/18 days it’s answered/solved I’d like this to be brought up again. Why is there not a pregnancy mode? I realize you can turn off period predictions, but so much more than that changes. Weight goals should change for pregnancy, your resting heart rate is usually dramatically different. Sleep is affected. FitBit, when will you acknowledge pregnant women and have a pregnancy mode that at the least turns off period predictions, weight goals, and let’s you track how far along you are?
04-26-2023 19:25
04-26-2023 19:25
Hi @Elmo_5 - that seems like a good suggestion for improving health monitoring especially as there is a feature suggestion that has been around since 2018 when the Versa watch series started, and has gone through 4 generations since.
It is not a small segment of the market either, with 267 births per minute worldwide.
