11-25-2022 07:24
11-25-2022 07:24
I have worn my Fitbit sense 4 now since 11/18 and I still can’t see a baseline for skin temp. My app is up to date as is my Fitbit still nothing. I am wearing it correctly, force quited and rebooted phone multiple times still no baseline yet.
11-26-2022 15:51
11-26-2022 15:51
I have been wearing my versa 4 for over a week and still no skin baseline. My app is up to date as is my versa. I have forced out the app and restarted my phone several times and still no base temp has been recorded. How do I get this fixed?
11-26-2022
23:25
11:15
11-26-2022
23:25
11:15
Hi @mrsmisfit4185 - As a Sense 4 doesn't exist your post was moved to Versa 4 to keep things organised. If you have a Sense 2 or other watch please specify which.
As regards baseline - the baseline is calculated automatically but no value is shown. If you are getting daily skin temperature readings then it is working normally. The readings merely show if your temperature is above or below the average.
11-29-2022 06:02 - edited 11-29-2022 06:04
Sorry that was a mistake it should say versa 4. I tried to delete post but couldn’t find a way to do that. I am not getting anything still says “wear for 3 nights”
11-29-2022 06:03
11-29-2022 06:03
There was a mistake in my post should say versa 4 not sense
06:10
11:15
11-29-2022
06:10
11:15
@mrsmisfit4185- thanks for the clarification. You can change the original text if you login to the community and click on the 3 dots and do Edit and re-post. It's already in the right forum.
Have you tried restarting the watch just in case it needs refreshing.
Best Answer11-29-2022 07:16
11-29-2022 07:16
Well now, I am seriously thinking of switching to another brand of smartwatch. I bought a Versa 4 about 2 to 3 weeks ago and I have worn it constantly since then, however… it is not recording my skin temperature. It says to wear for 3 nights 😂😂😂. Also, no wifi, my battery only lasts 3 days max and I do not get notifications of messages from my iPad or phone calls from my I phone. I had a Versa 2 prior to this one and I did not have the problems this model has. I am not a happy camper and either Fitbit gets their **ahem** together and solves these problems, or…
11-29-2022 07:33
11-29-2022 18:21
11-29-2022 18:21
I will try that tonight and give it another 3 days to see if that works.
Best Answer12-05-2022 20:47
12-05-2022 20:47
Still no baseline temp so assuming this doesn’t work. Even signed up for the premium and that did not help will be canceling that since it’s no help with this either.
12-05-2022 20:59
12-05-2022 20:59
@mrsmisfit4185- see this post skin temperature you may see something in Health metrics
Best Answer12-06-2022 19:28
12-06-2022 19:28
Thanks I do see it there. I cleared the cache even deleted the app and reinstalled but no luck. I will just check health metrics
01-01-2023 06:40
01-01-2023 06:40
I’m the same got this for Xmas and worn it for more than 3 nights and doesn’t work also my readiness score doesn’t work. My calls won’t connect to Bluetooth either. Have tried rebooting, turn off blue tooth, turn off phone etc and even forget device and re pairing. I have also done a factory reset and still no change. I have contacted support and they have did their best to help me but nothing working. I updated from charge 3 that was a great watch but it stopped working and you can’t buy them anymore
so fed up with this watch now and think I may have to return it. The Google pay works fine however. I wanted this watch as I have health issues and the baseline would be great if it worked
01-07-2023 08:59
01-07-2023 08:59
Mine is the same way, my sister got a Versa 4 also and hers said the same. No Baseline Yet, wear Fitbit for 3+ Nites. This has to be a software bug.
01-07-2023 09:06
01-07-2023 09:06
01-07-2023 09:17
01-07-2023 09:17
FitBit please update us on this issue.
01-07-2023 17:40
01-07-2023 17:40
So you are saying the Versa 2 is a better watch than the so called upgraded Versa 4? Please do not tell us that.
01-07-2023 23:47
01-07-2023 23:47
I is don’t know as I have never had versa 2. N previous watch was the charge 3
Best Answer01-10-2023 07:43
01-10-2023 07:43
I have the same problem. I’ve been wearing the Versa 4 every day and night for 2+ weeks. It still says must wear 3 nights to set a baseline. This seems to be a common problem based on the replies to your initial report here. Everything else with my Versa 4 is working fine so far other than the heart rate monitor occasionally getting stuck but that always resolves itself quickly.
01-10-2023 07:57
01-10-2023 07:57
Same issue over here. I have straight lines plotted over the three weeks I've been wearing my Versa 4 to bed, 0°F listed at the top of the graphs, and the pop-up message to "Wear for 3+ nights".
