Smart bike sync vs Fitbit logging
Hi all,
Brand new to the Fitbit community! I just bought a ShareVGo smart bike (stationary), which logs the typical distance/cal/mi/time/heartrate stuff and allows sync to Fitbit.
I also have a brand new Versa 4. I bought them to be compatible. I biked for the first time yesterday. On the Fitbit I selected Spinning when I began my session. Then when my session finished, the bike asked if I wanted to sync data to Fitbit. I said yes.
Now here's the issue, and I'm wondering the best way to resolve. This morning I checked Exercise in the Fitbit phone app, and I saw two results: Bike (apparently synced from ShareVGo) and Spinning (my manual selection). The spinning captures steps while ShareVGo doesn't.  The Bike activity from ShareVGo captures avg miles per hour and distance which Spinning doesn't.
Is there a reasonable way to integrate the two?
3 REPLIES 3
Steps are captured regardless of whether you track spinning or not. One thing that Fitbit does is record your HR (I believe ShareVGo doesn't send HR data?). There's no good way to integrate it. What I do, when riding Zwift or Rouvy I don't sync (well, anyway I can't) it with Fitbit. Just track both separately. Fitbit anyway doesn't recognize cycling as an activity that counts towards any stats.
Hello,
I just got fitbit but if it does not sync with zwift it  misses out almost al of activity s?
@Barrybest1980  It never worked for me. According to Zwift the sync is done only one way. Zwift can get your weight from Fitbit but won't sync activities into your Fitbit account. However, even syncing weight doesn't work for me (and I don't even see point of such integration).
