05-08-2024 09:00
05-08-2024 09:00
I'm a bit confused as to how the stress management score works. Apparently higher is better but to me the higher number indicates 70 - 100 (100 would mean I will be completely stress free, I would be comatose), but when I've googled it the info. coming up says that 70 is a low number and 0 - 40 would the high number (I would have less stress between 0 - 40)? Which is correct - does anyone know please?
Best Answer05-09-2024 09:48
05-09-2024 09:48
@AngelaMay A higher number is better. I don't think you'd be comatose with a score of 100, just very serene. You can get more information from this Help article page. The article covers other features, so I expanded the relevant section for you. If you tap on your Stress Management tile, there is a Learn More option just below the bar graphs. it gives a good description, too.
Laurie | Maryland
05-09-2024 09:48
05-09-2024 09:48
Laurie | Maryland
05-09-2024 10:03
