04-04-2025
18:24
20:17
ManuFitbit
04-04-2025
18:24
20:17
ManuFitbit
my device casually goes from 100 percent to 20 in less than 20 minutes, could this be due to a glitch?
Moderator edit: clarified subject.
Best Answer04-04-2025 19:56
04-04-2025 19:56
It's good to see you participating into the community @PattyBlues.
Thank you for sharing the inquiry regarding this difficulty with your Versa 4.
Please, make sure to follow the tips listed in this help article: Extend your Fitbit device's battery life.
04-04-2025 20:00
04-04-2025 20:00
Hi @PattyBlues - if your battery depletes very rapidly it is likely a serious internal fault, possibly from water getting in, and if it gets hot when charging stop immediately.
To confirm, you swiped the watch face down to get to Quick Settings to see the battery level and have restarted the watch by holding the button for 10 seconds, till the display blanks or it vibrates and waited for it to restart?
If it is under warranty you can seek a replacement.
04-05-2025 17:28
04-05-2025 17:28
Thank you so much for the feedback. It was helpful
