12-12-2024
08:29
12:56
MarioSFitbit
12-12-2024
08:29
12:56
MarioSFitbit
How do I put activities that I need on the main screen of Versa 4? Right now it has steps, heart rate, sleep. I want calories and not sleep. would also like battery level on.
12-12-2024 09:17
12-12-2024 09:17
@VPSK7 I apologize if I misread what you wrote. It sounds like you want to customize your current clock face. You might or might not be able to do that. It depends on the clock face. You can choose among many clock faces in the Gallery. Tap on the device/battery icon in the upper left of your Fitbit app, then your Versa 4 tile. Tap on the Gallery tile, then use the Search option in the upper right. Choose keywords that are important.
You can't customize all clock faces. The default clock face on the Versa 4 is called Paths Standard. It is a themed clock face and you can't change it.
Laurie | Maryland
12-12-2024 09:17
12-12-2024 09:17
Laurie | Maryland
12-12-2024
11:55
20:06
EstuardoFitbit
12-12-2024
11:55
20:06
EstuardoFitbit
thanks much 👍
12-12-2024 13:00
12-12-2024 13:00
@LZeeW Thank you for your help.
@VPSK7 , A warm welcome to the Community! Thank you for your message.
Just jumped in to add info to our friend's LZeeW reply. If you don't want to change the clock face, try tapping on the display of your Versa 4. By tapping on the display when the clock face is shown will change the stats shown (most of the clock faces support this) .
