03-22-2023
09:23
16:04
JuanFitbit
03-22-2023
09:23
16:04
JuanFitbit
As far as I can see the default auto recognition feature setting does NOT enable gps. However a treadmill run today, which my Versa 4 correctly recognised, also triggered the gps. The display had a red arrow as it couldn’t lock onto the signal because I was in the gym. I have noticed my battery has not been lasting long between charges and I suspect it’s the gps that is causing this.
Can I turn off the gps for auto recognised exercise? Is this what is causing other people’s problems with battery life?
03-23-2023 14:47
03-23-2023 14:47
Hello @Briman200 and welcome to the Community. You are correct that the auto recognition (SmartTrack) isn't supposed to turn on the GPS. There is a different auto recognition feature in the Versa 4/Sense 2 that will turn on the Exercise app with GPS (if enabled). This is on three exercise shortcuts: walk, run and bike. You need to turn this Off in your Run exercise shortcut:
Laurie | Maryland
03-23-2023 14:47
03-23-2023 14:47
Laurie | Maryland
03-23-2023 16:10
03-23-2023 16:10
Thanks for your reply and I have now updated the run detect setting.
I will test the fix tomorrow at the gym
03-24-2023 08:22
03-24-2023 08:22
Well that works and the exercise was still tracked but without triggering gps.
However I’m going to take the hit on battery life and reinstate the auto recognition. The monitoring of pace (even on a treadmill) is useful but particularly the cardio zones are an invaluable resource which I can monitor during training.
It would be ideal if gps could be isolated from the auto recognition - perhaps that’s something for a future software update from Fitbit.
