03-14-2023
23:20
17:29
JuanFitbit
03-14-2023
23:20
17:29
JuanFitbit
I can apply suica and ipass Both, but it's need suspend suica to use ipass ,then when I need suica card, the only way to do is remove ipass。Is there any simple way to change default card?
Best Answer03-15-2023 05:54
03-15-2023 05:54
Where are you located and able to add either ( SUICA ) or ( IPASS ). I purchased a Versa 4 through Amazon.Japan but ( SUICA ) is not and option for transit passes here in the US. I am guessing it only works if GPS detects you are in Japan.
Best Answer03-16-2023 06:21
03-16-2023 06:21
HI Bruce...
I'm in Taiwan..,also purchased versa4 from japan, ...add suica by using Gpay ..but need JCB card..
1. disable Location service on my pixel 7
2. using vpn software(openvpn or Surfshark app) to japan
3. add suica from fibit app
4. when using Gpay then register JCB card ....(Gpay is not support JCB in Taiwan , .therefor _need vpn _)..
5.then as sop on official website get suica.
But I need remove ipass for suica. because it's can not select.....
I dont know where can apply JCB @ US. It's seems only issue on ASIA.....
Best Answer03-17-2023 05:04
03-17-2023 05:04
Thank you "marrfy" for the suggestions. I tried what worked for you but it did not work for me, no matter what I tried, the list of transit passes only displayed USA based transport.
