Versa 4 Clock face
I just charged my Versa took it off the charger and now my watch has 3 different faces it changes to. I tried switching back to my old clock face that I had with Versa 2 it also now has to faces. I tried another one same thing. Any one else having this problem? I have synched it shut it off and still nothing. Always messing with stuff they can’t leave something that’s not broken alone!
4 REPLIES 4
It’s a Versa 4
Welcome back to the Fitbit community, @Truenole22!
Hoping that I understand your issue correctly, I'd like to point out that the option to have up to 5 clock faces on Versa 4 has been added with the latest firmware version to let you switch between those without having to open the Fitbit app.
You can however still use your Fitbit app to select whatever clock face you would like. More on that can be found here:
How do I change the clock face on my Fitbit device?
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2
Hi @Truenole22 - does it help if you pull down on the watch face to get to Quick Settings and turn off all the icons?
