04-27-2025
06:52
07:55
MarioSFitbit
04-27-2025
06:52
07:55
MarioSFitbit
I have had to turn off GPS on all my walks and runs as the vibration is so frustrating. I got the Fitbit versa 4 for GPS reasons and it's totally unusable and it just vibrates constantly. It is not heart rate notifications all other are turned off. Is anyone else having trouble with this
Moderator edit - updated subject for clarity
05-01-2025 07:59
05-01-2025 07:59
I am having the exact same issue. My watch is still in warranty and I contacted support. I had to reach out like 5 times because each time they would get me to do obvious troubleshooting steps (turn it off then on) and send me on my way without actually helping. It seriously ruins your run when you can't focus on anything but your watch buzzing like crazy every step you take. They offered me a replacement but expected me to send in my faulty product and wait two weeks for a replacement. I explained that going two weeks without would totally throw off my stats and they didn't care. Not that long ago Fitbit wouldn't even require you to send back the old product and they certainly wouldn't leave you without one. Now that Google took over, all the features are being discontinued and the customer service sucks. Sorry to hear you're in the same situation. I'll never buy from fitbit again.
05-01-2025 08:52
05-01-2025 08:52
Same problem here. So annoying. Even lost some exersize-data. I am really disappointed. Do they say if it is hardware related or is it just the processing? The latter should be fixable....
05-01-2025 11:00
05-01-2025 11:00
When I contacted support they had me do factory resets and a bunch of other troubleshooting and even asked me to take pictures of my fitbit with the flashing gps sign to prove it was happening. Then they offered to replace the hardware. From the number of posts reporting this issue, I don't think a replacement would solve anything for me anyway. If it wasn't hardware I don't know why they would offer a replacement.
05-12-2025 06:00
05-12-2025 06:00
So I've actually had my GPS turned off on all exercise for about a month and I turned it on last night as I wanted to track a walk without my phone and touch wood it actually didn't do anything. No unnecessary vibrations or reconnection. I'm hoping this lasts and I can keep GPS on
Best Answer05-12-2025 06:24
05-12-2025 06:24
Best Answer05-12-2025 07:42
05-12-2025 07:42
05-12-2025 11:55
05-12-2025 11:55
Just want to add I have had the same issue where mine does not have straight lines and has even been so bad to show I ran through a large pond which obviously I did not and totally skewed the stats for my run as well.
Best Answer05-13-2025 05:52
05-13-2025 05:52
