12-27-2024 05:55
12-27-2024 05:55
My Versa 4 goes to sleep mode on its own.
How do I change settings so that it doesn't do this.
Thanks,
chuckles1983
12-27-2024 06:44
12-27-2024 06:44
Hi @chuckles1983 It's great to see you in the Community!
Let me help you with your question about the sleep mode of your Versa 4.
Sleep mode turns off automatically when you set a sleep schedule. To set a schedule:
Note: You can't turn on do not disturb and sleep mode at the same time.
I wish you a happy holiday season!
12-27-2024 09:58
12-27-2024 09:58
Thank you for your quick reply.
What I don't want is for the watch to go into sleep mode.
The watch has not been set to go into sleep mode, but late at night the watch seems to go into sleep mode.
Thanks,
chuckles1983
Best Answer12-27-2024 13:29
12-27-2024 13:29
Mine does the same thing.
Best Answer12-30-2024 00:38
12-30-2024 00:38
Yep, so does mine. It is annoying as sometimes I need to get notifications during the night, even if I am asleep. Would like to know how to stop sleep mode automatically coming on, when I didn't ask it to.
01-08-2025 08:20
01-08-2025 08:20
Mine does this as well. It is only started doing it in the last week or so. I have checked the settings and they all appear to be correct.
Best Answer01-29-2025 19:33
01-29-2025 19:33
Yep. My Versa 4 started going into sleep mode automatically too about 2 weeks ago. I have sleep schedule turned off, as well. Very frustrating. Fitbit needs to fix this glitch.
Best Answer02-13-2025 21:37
02-13-2025 21:37
My Versa 4 is going into sleep mode on its own. I have checked the settings and I do not have a sleep schedule set. Is there another solution to stop this from happening?
